It is currently Wed Aug 20, 2025 8:58 pm
 Post subject: Big tuner layout mistake
PostPosted: Mon Jan 06, 2014 9:33 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I've been finishing up a soprano ukulele and decided to instal the tuner even though I was feeling sick. Upon installing the tuners, I realized that I had completely misaligned the tuners on the left side of the peg head. Is there anything I can do to correct this problem? I thought of possibly filling the holes in the back, with some more maple, touching that up and replacing the peg head veneer. Any better solutions?
PostPosted: Mon Jan 06, 2014 9:46 pm
City: winnipeg
State: manitoba
Country: canada
That sounds doable to me except use dowel to fill the holes.
I carefully measured for a tuner on the top of the head but found that it drilled better from the bottom of the head when I used the drill-press. Laid it out using the same measurements and drilled it on the other side of the head. I now have a ukulele with three tuners on one side of the head and one tuner on the other side. It looks artistic.
Bob :ugeek:
PostPosted: Mon Jan 06, 2014 10:48 pm
What Filippo said.
Old growth, shmold growth!
PostPosted: Mon Jan 06, 2014 11:17 pm
Or...leave the tuners and cut the head on the left side in an artistically, asymmetrical shape. Clinton
PostPosted: Tue Jan 07, 2014 6:06 am
Inlay
PostPosted: Tue Jan 07, 2014 9:32 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I did the same thing on this little L-1. I didn't fix it thinking I would see how obvious it was - I am not going to fix it.
Ed Minch
PostPosted: Tue Jan 07, 2014 12:31 pm
as stated above. plug, re-drill, new veneer. or use the jedi mind trick. "those aren't the tuners you see off-center..."
PostPosted: Tue Jan 07, 2014 1:19 pm
First name: Robbie
Last Name: Fraelich
Maybe you could reshape the headstock to make it look more symmetrical or asymmetrical/intentional.
PostPosted: Sun Jan 12, 2014 11:03 pm
First name: Jeff
Last Name: Crisp
State: Victoria
Can you move one side in a couple of mils and the other side out a couple of mils, after plugging both sides?
PostPosted: Mon Jan 13, 2014 10:56 am
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
I'd say your best option has already been mentioned, but if you want something quicker and have the correct sized plug cutter, you could stick a dowel in the hole, then cap it with a piece of rosewood you cut using your plug cutter. Although, a new veneer is basically just as much work anyway.
